Anyone have one that I can borrow for a day? Looking for a bent valve.
Leak down tester
While you have it running, did you ever check the AFR? If so, is it within reason? ITB balanced? ECU crank timing calibrated? TPS response normal (not reverse and steady rising) and ECU calibrated for TPS? Fuel pressure on target and stable? Do all injectors actually squirt?
Sorry if I am asking the obvious...another problem that I saw on one engine (forgot who's it was) the throttle bodies had vacuum nipples on the underside that lost their caps.
I doubt it is a bent valve with the compression values you mentioned in another post. I had much worse pitted valve leakage on my old engine and it idled o.k.
