Fixed: "Invalid Redirect URL" when logging in.
  • Fixed: "Invalid Redirect URL" when logging in.
    The invalid redirect sometimes popped up when I logged in. A quick google and setting change seem to have fixed it.
    Please reply to this thread if you still see it.
    I got it this morning. 1st trip to the updated site.
      I also saw it the first time I tried to log-in this morning (first try with this machine). Worked properly on the second try.
        I got the message the first time I logged in. If I log out and then log back in I am still gettting the message.
        Invalid Redirect URL (http://www.californiacaterhamclub.com/chat/)
          I had the same problem today. Logged out and back in, still an issue. Closed and re-opened browser, still an issue. I edited my Bookmark/Favorite to remove the "www." from the URL, and it works fine now (?).
          URL I am now using: http://californiacaterhamclub.com/chat/
          Whatever works.
            I also received the same message and the site dose not seem to remember my log on when the box is checked but I can live with that.
            Thanks for the site.
            Martin Keller
            Ventura, Ca.
              If you have an existing .httaccess in the root of the domain, add in:
              RewriteEngine On
              RewriteBase /
              RewriteCond % ^www.californiacaterhamclub.com [NC]
              RewriteRule ^(.*)$ htp://californiacaterhamclub/$1 [L,R=301]
              If you do not have an .httaccess, you can create one using the above. This should redirect anything with www to a non-www which is the root (no pun intended) of the issue I think.
              http://www.zenoscarsusa.com Official importer of the Zenos E10
              http://www.theadrenalinegallery.com Your USA dealer for Levante Cars, Origin Cars, Minotaur Racing, Sadev Gearboxes, RST V8 Engines, and more... How fast do you want to go?
                I'm getting the invalid redirect error, both yesterday and today, when I check the "remember me" box. But, not when I don't.
                Randall
                  Randall
                  Same here....
                    I still get this if I log out and log back in with the remember me box checked.
                    If you just ignore it and click on Forum it will take you there and remember you for next time.
                    Once you do that it works fine as long as it continues to 'remember me'.
                      I also noticed some strangeness on the invalid redirect page. At the bottom, this appears:
                      "All times are GMT%1$s. The time now is %2$s.
                      Powered by vBulletinآ® Version %1$s
                      Copyright آ© %2$s vBulletin Solutions, Inc. All rights reserved."
                        Should be fixed.
                        Please tell me if you still have issues.
                        randychase: The regexp you wrote didn't trigger for some reason, so I stole another example from the net and tried that. The redirect now works.
                          It seems to be working now.
                          Thanks.
                            Yay!
