I put the FIA roll bar on today, which was very easy. Just bolted on without any trouble. The Side Intrusion Bar was a little trickier, because you have to find the threaded boss underneath the skin on the side of the car. With David L.'s help, I was able to locate it without drilling any unnecessary holes. Note how it overlaps with the rivet hole from the tonneau cover, which had to be removed. The only problem is that the hole in the bar doesn't quite line up with the threaded boss. It's about a half inch off. I haven't decided if I should make the hole on the bar brace bigger, or come up with some other solution.
The hole for the strut brace on the passenger's side will be easy to find now that I found the driver's side hole. And no, my car isn't gold, the lighting in the garage is just strange!
