The upper mount for the rear shock is very tight. There is only about a quarter inch from the head of the bolt to the skin. So how are you supposed to get this bolt out? I am thinking of cutting a hole in the skin over the bolt, and then putting a cover over it later. Any thoughts?
BTW, the ID of the metal sleeves in the AVO shock ends is slightly smaller than the bilsteins, so I drilled them out with a 1/2 inch drill to accept the inner sleeves.
Thanks as always for the help and advice!
