First a simple question. Seems obvious, but I don't want to break anything. There is a cap in the center of the front hub. I assume you put a screwdriver or something in the hole in the center and pry it off to get to the hub bolt? I tried with moderate pressure and it didn't give. I can't get a visegrip to take purchase on the outer rim. I have new hubs, but not new center caps, so I'm just being cautious.
Second, I have the grey AP brakes. The metric wrenches didn't fit right on the calipers, and a 5/8" was a little sloppy. Are these a British SAE? I had a set of wrenches for my Triumph, but no longer have them.
BTW, notice all the rust! At some point I'm going to need to take apart most of the suspension and do some cleaning and painting.
