I took my car to an engine tuner on my side of the country to check some possible engine management programming issues, and to see what kind of horsepower and torque the car made at the wheels. The first run produced 129 hp, and had to be aborted at 6000 rpm because the air/fuel ratio was 15:1 and the exhaust gas temperature was 1500 degrees, so we feared that engine damage could result. This is with a new SVT Zetec motor, plus the Kent camshaft upgrade, both purchased from Caterham USA (car had 1000 miles on it at the time). The last run was done 9 hours later, and produced about 147 hp, with the following engine changes: custom PCM reprogram, vct eliminator, and adjustable cam gears. I have the following questions:
What is the typical drive train loss from crank hp to wheel hp as a percentage for the Caterham?
Has anyone else dyno'ed their SVT motor, with or without the Kent cams, and would you post your dyno run?
Is the drop in torque and hp from 2700-3700 rpm normal?
Why is my motor only making this much power?
Why would the stock PCM allow the car to run so lean?
The motor was represented to me as a 180 hp motor in stock trim, and 200 hp with the Kent cams. The SVT motor, as built by Ford, produces 170 hp at the crank when installed in an SVT Focus. Assuming a 15 or 20% drive train loss, I am as much as 50 hp down from those numbers. I emailed Kent cams for their input, and they said they made the cams to Caterham USA's specs, and couldn't help me. I've also included a chart sent to me by Caterham USA when I was considering whether or not to buy the cam upgrade. Clearly, it's much different. My tuner said this chart does not look like a Zetec motor's power curve. Anyone have any thoughts on this engine chart? The car was purchased as a turn key car, so I didn't assemble any of it (if I had, it probably wouldn't run at all).
