My car is still in the shop four months later (!), and in the final stages (?) of the engine rebuild. They went over the bill with me today, and basically for the price of this old beat-up seven, parts upgrades, and engine rebuild, I am coming close to the price of a new caterham. And it still is rusty, tired, and needs some work! I'm sure I won't feel so bad once I get it back on the road.
They are having trouble with the Emerald ECU. They can't get the com light on the ECU to come on, and can't communicate between their laptop and the ECU at all. It has no pre-programmed map, so until we can sort this out we can't start it. It does fire up the fuel pump and injectors when the ignition is on, but that's all. They have been corresponding with Emerald, and still working on a fix. Anyone familiar with these systems? I'll give Woody at MSI a call later, but just curious to hear if anyone has experienced the same thing.
Done so far:
pre-98 Zetec rebuilt to race specs with:
- blueprinting, match and balance, deburring, oversize valves
- original kent cams
- Jenvey throttle bodies
- Emerald ECU
- new wiring harness
Sitting in the garage waiting to install:
- Freestyle motorsports damper/springs, sway bars, adj. ball joints, shims
- RIF aeroscreen and mirrors
- Caterham aluminum hub upgrade kit
- rear spindles, brake pads (need to have discs resurfaced)
- FIA rollbar and strut
Done so far:
- Emerald ECU
