Upper wishbone rear mount
  • Upper wishbone rear mount
    Hi,
    I have a problem and could use some advice. The upper wishbone rear mount is slightly misaligned between 1/16 -1/8". I attached a picture as well. Please note that I am able to mount the upper and lower wishbone on the other side of the car.
    Suggestions are welcome and appreciated. I have tried search blatchat as well.
    This is what I receive from Caterham
    > I've run through the pics with Engineering and we
    > are satisfied that the
    > misalignment, whilst undesirable, is not excessive
    > and has been
    > experienced in the past on many cars.
    > The solution is to 'spread' the wishbone mounting
    > bracket which will
    > bring the bolt holes into line. Once the wishbone
    > is fitted and
    > tightened, it will bring it back together.
    > This will not affect the geometry beyond the norm.
    > Regards
    > Simon Lambert
    > Commercial Manager
    > Caterham Cars Limited, 2 Kennet Road, Dartford,
    > Kent, DA1 4QN
    > *** Please note that any opinions presented in
    > this email are solely
    > those of the author and do not necessarily represent
    > those of Caterham
    > Cars Ltd. This email and any attachments are
    > confidential and intended
    I think Caterham is correct and that you should be able to get it together OK.
    Please send me some higher resolution photos. I sent you my direct eamil address.
      Their response seems reasonable to me. I suspect it will fit just fine if you use a bigger hammer! :p :eek: :D
        My feelings exactly about the big hammer. I did find one potential solution. A suggestion of using a bolt and a nut to spread the flanges farther apart. At least I won't take the frame and body with it that way.
        If there are any other suggestions, I would greatly appreciate them.
          I would tend to want to remove it from the car before I attempted to spread it. This prevents the chance of cosmetic and/or structural damage to the car.
          Have you posted pictures somewhere of the wishbone with respect to the mounting points?
          EDIT: They cannot be removed. Doh!
            The flanges are welded to the frame and next to the shell which is riveted to the frame. I wish I could take it off.
