My SV has been having overheating problems on the track since I got it, with or without water wetter. According to blatchat, a part of the problem is that a large amount of air passes on the side of the stock radiator; a problem which can be fixed quite easily.
Even with this in mind, I've been thinking about getting a beefier radiator for the Duratec since I will probably go for a laminova oil cooler setup which will increase the load on the cooling system.
Is there an aftermarket unit that can easily be installed in an SV, or should I just give Caterham a call?
