Hi All,
I have a 1700 Crossflow with a big cam. After installing my starter, I cranked the motor but the battery seems to look power before the motor starts.
Is there an aftermarket battery with longer crank power that someone can suggest?
Also, I noticed the pinion gear stays connected to the flywheel ring gear after cranking, is that going to create a problem once the motor starts?
Scott
Scott
