I have a complete set with all the numbers but I would say it is best to get it from Caterham USA with all the seals too. Not too difficult to install, the option being to buy the entire hub complete with bearings and seals.
Caterham cunningly remove the bearings from their manufacturer's packaging, so you have to read the part numbers off the bearings themselves. This is just about impossible - being the cheap bastard that I am I have examined several sets with a magnifying glass and the bloody zeros and eights and sixes all look the same. So I just order from Cody.
However, Caterham slipped up and shipped my front axle upgrade package with the bearings in their original packaging. Here are the numbers in case you have that setup:
NTN 4T-L44643L/ L44610
This part number(s) should get you one box containing all the parts for one wheel (inside and outside bearing and two races). Unlike the old triumph bearings, which have separate seals made of sackcloth and whale oil taken from an 18th century sailing ship, the uprated bearings have a nifty rubber seal integrated with the bearings themselves. Oh-so twentieth century.
