Hi, Folks.
I'm new to the forum, and am currently in the process of building a Locost chassis that is being adjusted to suit my preferences. As my car is using mechanicals that closely parallel those used by US Caterhams, I hope you won't mind me asking a few questions.
I am using a Focus SVT Zetec with a Sierra Type 9 out of a Merkur XR4Ti. I was planning on using the Sierra diff from the Merkur in a De Dion format, but am using Miata front uprights/hubs/wheels (due to the favorable geometry), and I would like the bolt-pattern to match front and rear. So, I am now considering using Miata both front and rear, which will likely result in a 3.9 - 4.3 final drive. Now to my concern:
With such a low (numerically high) final drive ratio, I am concerned about the effectiveness of the 3.36:1 first gear in the Type 9. I really would like to avoid having a useless first gear, and wonder if there is reasonable and local source for a taller first gear. I believe that one can be sourced by BGH Geartech in the UK, and I can go there if necessary, but would prefer to find something in North America (I am in Vancouver, Canada).
So, are my concerns valid? Will the first gear be a problem? If so, what options are there for a taller first gear?
Thanks for your time!
Shaun Laughy
Shaun Laughy
