I recently purchased a Caterham Club Sport and am in the process of assembling the car myself in my spare time.
I was bolting the independent rear center section to the frame and ran into a problem....
I was able to bolt the top and rightside bracket without any problem, the leftside frame bracket wouldn't line up properly with the thread pattern on the center section, it was off by approximately 1/16th of an inch or possibly a little less.
Has anyone ever dealt with this situation before and if so how did you resolve the problem?
(I tried putting the leftside on first then the rightside but the left still didn't line up correctly).
A second question on a different part.... once you have the steering rack, rod end in place and bolted down how do you adjust the toe in toe out?
