The throttle response on my Seven has been fairly poor lately and getting worse over time. Today, I checked the fuel pressure and found it is only 15 psi. The spec for the Ford Contour Zetec is 30-40psi. The fuel filter has less than 1,000 miles and all other sensors, injectors, etc. seem to be working fine. This leads me back to my fuel pump having given me its best, but sadly, getting worn out.
My car is a 1999 Zetec-America and the engine is still in stock form as delivered. The car has over 92,000 miles on the odo.
The in-tank fuel pump has the following numbers on the pump body: 6443327, and C1159-1. There is one other number stamped into the plastic fitting on one end: 2126.
Does anyone have a line on these pumps or recommendation where to get one? Or possible upgrades?
I appreciate the help!
