SAE 75W90, API GL-4 (do NOT use GL-5!)
EP90
DOT 4 (do NOT use DOT 5!)
I used Redline MT-90 in my 5-speed (their MTL is SAE 75W80, and MT-90 is SAE 75W90). Can't recall what I last used in either diff or brake/clutch lines.
