Got more information that may help you , help me!
The dist between my four wheel studs is 3.75", I'm sure I have the ITAL diff ('92) but not sure what the spacing of 3.75" tells me with respect to the ratio etc of the diff as I am a newbie on the list.
I put the car up on my hoist and put the parking brake on, I rotated the U joint in front of the crown/pinnion (diff) and I got about a 1/2" play, nothing to worry about pretty typical for this type of set up (I think). BUT, when I put a screw driver in to the U joint, and applied a bit of force I could get the U joint to move, or more like "snap" yet ANOTHER 1/2" till it "bit" in to the hubs/wheels to go forward and heard what I can only think if I was driving the car the "clunk" at the hub end as I've talked about before.
I'm as sure as I can be this is why I'm getting the clunk, but what is the cause?
Thoughts?
Thanks, pat
Thoughts?
Thanks, pat
