Over the past year or so, I’ve noticed some ominous sounds (clunks and knocks) emanating from the back of our Seven. They only happened at low speed (at least that’s when I could hear them), and usually when the clutch was depressed and we were rolling to a stop. The sounds occurred on smooth roads, so hitting a bump was not involved. More recently, I’ve noticed repetitive knocks at what I’d consider to be axle (not driveshaft) speed, again usually after de-clutching and rolling to a stop.
Does this sound like a CV joint problem in development? What's the check for CV joint wear? For u-joints, it was just looking for play. Has anyone had a similar issue?
Best wishes,
Best wishes,
