The past month or two, my car sometimes seems to want to overheat when it shouldn't, and hadn't before in similar (and worse) conditions. Expansion tank level seems to change a bit, but sporadically. I'm thinking this is likely to be head gasket failure, probably related to the thrown belt overheat I had in the summer, and possibly magnified by a day of flogging it around the track a couple weeks ago.
This brings up a couple of Qs:
1. How to definitively tell if this is HGF?
2. If not, what else might cause this behavior?
3. Any tips on what to do/avoid doing when changing a head gasket?
Any pointers greatly appreciated, as I've only changed a HG once before, and it was a good few years back.
edit -- Oh yeah, my speedo quit working on Friday as well. That one should be easy enough.
