I noticed my steering column is very lightly rubbing the side of an exhaust header. I had some high temp grease I put on the spot, but long term I'm thinking these two shouldn't touch.
I've read about MG's having their engines sink over time from the engine mounts. Has anyone had that problem with a Caterham? I have the round mounts. I expect they didn't always rub, but have settled into place.
The way I see it, I have two choices. a) Replace mounts or get some shims to raise the engine a bit. Or b) remove the steering column and dent the header a bit until it doesn't rub.
I'm not very keen on denting the exhaust, even though it only needs a millimeter or two until it's free of the column. If others have had problems with the mounts compressing, I can imagine being back at squiare one in a couple of years.
Thoughts?
Thoughts?
