Duratec dipstick references (with wet sump)
  • Duratec dipstick references (with wet sump)
    Can someone with a Duratec/wet sump give me a few measurements when they have a chance:
    1) Hilt of dipstick to "full" dot
    2) Hilt of dipstick to bottom tip of dipstick
    3) Top of dipstick tube where the hilt rests to surface of casting where tube fitting is threaded in (following the tube down).
    Much appreciated..
    sigpic
    2010 Roadsport SV 170
    1) Hilt of dipstick to "full" dot = 18 1/2"
    2) Hilt of dipstick to bottom tip of dipstick = 19 5/16"
    3) Top of dipstick tube where the hilt rests to surface of casting = 20"
    This last reading is quite dependent on how long the rubber tube is, that connects the barbed tube connector on the bottom to the top metal dipstick tube. So mine is 20" - this is not necessarily correct, noting that it has a bend to avoid the oil cooler pipes.
      Thanks!
      sigpic
