Hey Sean (or any other interested parties of course), didn't you think about installing one of those Modine oil coolers in your car at one point along the way. I'm interested in knowing what you thought about them, and what you ended up doing. CC shows one on their web site.
Tom, I bled the clutch and tested it. All seems well, as near as I can tell. I was sat (English English :-/) in the car and put the transmission in gear. Then pressed the clutch, reached back to the left rear wheel to see if I could turn it, then released the clutch to see if I couldn't turn it. My sense is that if you go w/ the same thickness adapter that I have (8mm) you should be OK. I used the same clutch slave that you purchased.
Some big purchases ahead, in the near future as things start coming together. I'm very motivated to move the project forward now. :-D
