I'm sure it's possible...although I don't think I would bother. You just need to get used to shifting with your other hand!
Here's a guess at what you would need to do:
Replace the scuttle - it has a support for the steering wheel
replace the dash
move all of the gauges - might require re-wiring
move the heater control
move the battery master switch (if fitted)
Move the pedal box
replumb the brakes/clutch/gas cables/lines
flip the steering rack
