At the dyno day, it was noticed that I had a fuel flow issue at higher rpm. At the gas station the other day, I had a different fuel flow issue where it was trickling out underneath the car. It seems that the short, large diameter hose between the fuel filler-up-a-lyzer and the fuel tank has developed a "vent" - a crack along the seam. The rubber feels kind of old too, if that makes sense. Anyway, I will obviously be replacing the hose a.s.a.p., but was wondering if any here might know if this could have been the cause of the original issue: fuel pressure dropping off at mid- to high-rpm?
Fuel flow issue
Yes, I couldn't see how it could be related, but it sure did seem like a coincidence. I have replaced it this evening, and went ahead and re-did the vent per the grads race series as found here.
Next time I am somewhere I feel noise will not be an issue, and I have somebody with me, I'll rev it up and see if the fuel pressure drop is still there. I may have to see about making a Gert-style mega-muffler so I can rev as needed at home in the future.| | Sean
The two things *may* be related...in a bad way. If the filler hose has rotted and shed little bits of black crud into your tank, those bits may have partially blocked your fuel delivery system somewhere (hopefully in a filter, not just in the line itself) so that you get enough flow at lower demand but not enough for WOT.
I don't think that rubber would clog the pump or the filter since there is a a sock on the pickup in the tank that will take care of any debris large-scale debris.
During the dyno runs Sean's pressure dropped to 35psi (down from 55 or so) at the top end. I compensated for this with longer injector duty cycles, but at that pressure fuel atomization does take a fairly major hit.
The stock in-tank pump usually poops out trying to feed engines above 200HP; I had to replace mine when I supercharged my old Zetec to around 210HP. (There's a thread somewhere with pics describing the plumping I did).
I still think a pump upgrade is the right thing to do, which does not have to be expensive, although a remap will be needed since there will be way too much fuel at the top end with a beefed up pump.
I've never inspected an upgraded pump, thus cannot tell if its presence can be determined from the outside.
The upgraded one:
http://www.caterhamparts.co.uk/produ...d_product=4541
The standard one:
http://www.caterhamparts.co.uk/produ...?id_product=98
They look more or less identical, which is a surprise. The sock I mentioned earlier is clearly visible in these pictures.
If you have an upgraded pump (which I doubt), you probably have a clogged filter. Easily replaced.
