Duratec Alternator
  • Duratec Alternator
    Howdy everyone,
    My alternator is starting to make a noise...sounds like one of the bearings is going out. I'm thinking of rebuilding it myself (bearings are cheap), but I'm also thinking of replacing it. It is a one wire Denso alternator (the sticker claims 55A). Unfortunately I have not been able to locate the exact replacement. This is the closest thing I could find http://www.gzmotorsports.com/images/.../A106-side.jpg. I would need to switch the pulley. I either need to find a replacement alternator that will fit my current mount or buy/make new mounts in addition to getting a new alternator.
    I'm wondering what alternator the other duratec owners are using?
    I have no info on Duratec alternators. But I would not bother rebuilding yourself. The local rebuild shops here in LA will do it for 30-40 bucks. If you consider your time for research, ordering and wrenching it may not be worth it.
      I agree with Gert.
      Although Wagner alternator is a good source a rebuilder gets the parts at a bigger discount.
      On the other hand Wagner can UPS you the parts if chasing a rebuild shop is a problem. They aren't hard to do yourself.
      http://www.wagneralt.com/
      Great for starter parts too.
      Rick Wagner was very helpful.
