I discovered the right side engine mounting bolts that conect to the engine have shear off flush in the block. No idea when it happened. It could have been just before I noticed the exhaust was sitting on the bottom of it's exit hole from the body work.
(I was 20 miles from home and drove home and drove home ok).
It could have even been like it since I bought the car two years ago.
Anyway, here's what they look like,
and
https://files.me.com/paulrabjohns/gl75i1
I was thinking I need to remove the exhaust from the engine, then remove the engine mount from the frame, buy a 90 degree drill chuck and some kind of easy-out to try and get the bolts out of the engine.
Here's a few questions,
this will be by far the trickiest thing I've had to do yet.
Will I need to get a new gasket for the exhaust? if so anyone know where from. My engine is a zetec zx1.
Also anyone know what bolts I need to replace the sheared off bolts?
Can I jack the engine up to line it up against the engine mount to put the new bolts in?
Can the sump take the weight or should I jack somewhere else?
Any tricks, tips or advice gratefully recieved.
-Paul
and
-Paul
