Birkin axle bearing.
  • Birkin axle bearing.
    Hey Guys, My Birkin (approx '03) needs an RR outside axle bearing. The bearing also serves as a seal & it's barfing diff oil onto my wheel. A while back I ordered Dick Brink's last one but it had a pinhole in the rubber. The only Hilux supplier I found stateside sent me a mis-match. I could try matching "by size" but would really rather just have the stock unit. Any ideas? Thanks--Perry.
    Can not help directly but did you ask on the Birkinowners Yahoo list? Contacting the factor may be another option but I am surprised that Dick brink would not have any more. He usually has almost anything imaginable.
      I had the same problem and Larry from Woody's shop fixed the leak with a seal from Napa. You can give him a call to get the part number. He might be able to help source a bearing too. MSI Motorsports 707-448-3322
        Yes, Dick has a lot of stuff. I got my Quaife from him + other things too. Maybe I will give him a call again because it has been awhile since I bought his last bearing.
        And I left a message for Larry at Motoring Specialists too for that Napa seal. Question: Was it a separate seal? My setup seems to be a bearing/seal one piece unit. Thanks.
          Yes, it was a separate seal. My bearing was fine so it wasn't replaced.
            Do you know the donor axle?
            You should be able to find it that way or get the number off the seal and take it to a parts store. If no number take the old one.
            Seals are like bearings, mfgs use existing sizes whenever possible.
              Doug. If I knew it was just a '05 Tacoma or simmilar setup, of course I'd have no problem. but it's a Hilux axle of POSSIBLY 2003 manufacture of probably African orgin.
              It's just one of those numbers-match-nothing situations. And now there's a separate seal? Like a paper flange gasket or O-ring? Was my axle assembled with a part missing?
              My last resort is the Roscoe's House Of Bearings type effort.
              No worries, Guys. I have Larry & Dick on the case.
              Thanks again.
