I was up at Willow this week on the balcony and after a good thrashing around noticed a nasty noise on start up. Trailered it to the Morgan dealership in Santa Monica. Tony removed the sump and reckons the big end bearing on #3 cylinder is the problem. I'm awaiting an estimate but it ain't gonna be pretty I'm sure.
So, questions for you guys:
1. Anyone have experience of the Morgan dealership service shop? I think I recall Scott saying he'd used them. Scott, what did you have done and did Tony do the work?
2. Any other recommendations on places to take it?
3. I'm assuming this happened because of oil starvation so I'm thinking I should fit a dry sump if I'm going to repair this and do more track time. (The engine only has about 3K on it, damn it.). If so, go with the Caterham system, Burton's or something else?
4. On the other hand, how much is this all likely to cost - engine out, strip down, crank machining, balancing? replace just the failed bearing or all etc etc?
5. Maybe it's time for a Duratech and some serious power? But that means engine management, fuel injectors, bodywork since the exhaust comes out the other side etc. Sounds very expensive. And again, where to have it done?
Any advice welcome.
Any advice welcome.
