So yesterday I took the Caterham out for a test drive, and it promptly overheated since I hadn't topped up the system prior to taking off.
Coolant loss has been a minor issue ever since I built the engine. The raceline water rail has a relief valve in its cap that opens at 20 psi to let excess water out from the system into an unpressurised catch tank. The hose enters the tank, which is always about half full, at the bottom. When the engine cools the coolant system sucks water back from the tank back into the main loop. Or so it is supposed to.
Every time when the car starts to heat up, I smell coolant-on-header for a while indicating that the system leaks during its heating phase. After a drive I have to add a bit of ounces of water. Yesterday I'd forgotten the adding part for the third time, and things went south.
Today I topped off the coolant, bled everything and fired up the car at the driveway while going over it with the IR thermometer. A drop or two of water from the thermostat housing gasket, but not enough to explain the loss. The radiator, once the thermostat opened, got evenly warm. The fan kicked in (in the correct direction) at 90-95 degrees and drove the temperature down immediately.
In conclusion the system seems to leak only while driving, although I cannot see how. Everything is sealed, and the catch tank vents at its top. I just have to drive regularly for this to happen, no Gs necessary.
So my question is, what happens if I eliminate the catch tank setup entirely and plug the relief valve hole and replace the cap with a regular radiator cap?
Alternative two is to plug the hole and setup a pressurised expansion tank.
Suggestions are most welcome.
