Hi all, I have run into an issue that is "solved" but I do not know how many people are aware of this issue. First if you are installing a new starter for the ZTech engine the starter opening is too small. The solution is to grind half of the opening off. It ends up being a 180 degree arch.
The second issue is you can get to two of the bolts, but not the third. The solution is to unbolt and drop the engine a small amount. I am not mechanically inclined enough to do this on my own, so I used http://evilgeniusracing.com to do it for me. They fabbed a special tool to accomplish the de-install and the re-install of the starter.
I bought the starter from Dick Brink and I am sure I had the right one and the car now starts without issue. I bought the more powerful starter, as the stock one simply did not cut it.
This is FYI for people like me who did "not" build their own car. I am also having Evil Genius Racing to build a custom roll cage.
Scott
Scott
