Whew, took longer than anticipated but as it goes, one thing came to another and once you take the car apart you find things you really don't expect. Anyway, it was a good investment of 6 or 7 weekends. Here is the list of repairs and upgrades after the trip to Monterey:
- broken starter rebuilt
- welded large crack in the Raceco exhaust (already 2nd time that happened)
- fabricated exhaust vibration damper (so it does not happen again)
- replaced ripped motor mounts
- removed steering rack, lubed, new rubber boots, removed suspension and radiator
- stripped frond end completely, sanded and primer coated chassis tubing.
- purchased and installed Birkin wide-track suspension kit (new wishbones, ARB, uprights and shock bracket)
- replaced corroded front bearings
- blasted, painted front calipers and rebuilt seals
- re-routed brake tubing for widetrack change
- relocated remote oil filter and installed new oil hoses (also due to widetrack change)
- fabricated new front wing stays/brackets from stainless tubing. More rigid and giving more space for 205 wide tires.
- relocated my homemade headlights to the new shock mounting bracket and fabricated a better swivel joint for adjustment.
- hammered a big dent out of my sump guard and welded up the impact zone with another steel strip.
- synchronized throttle bodies and changed oil
- recovered $250 by selling the old suspension to a guy in Australia (racing accident)
So, quite a bit of work but I guess I neglected proper maintenance for a while.
some pictures here.
some pictures here.
