Yesterday I started fitting the my Tillet seats and ran into trouble with the crotch strap.
The strap starts at the lap belt mounts, goes under the Tillet seat and through the hole where your private Seven (inches) has a tendency to fall down when you are driving naked.
I tried to pass the strap from its seat belt mount, between the runner and the seat (which are separated by a couple of spacers and through the hole. The problem with this is that the bracket used to adjust the strap gets all bunched up between the seat belt mount and the seat itself.
Should I try to move the bracket so that it resides under the seat on the part of the strap that is between the runner and the hole, or is there a smarter way of routing it?
