We finished our home remodel so I have finally brought the Seven home. I did a little bit of work on it over the weekend and again this evening:
1) Removed the old 10" wide steel wheels and tires
2) Removed the Spridget rear axle and installed a proper TR-10 with LSD reworked by Chris Beebe
3) Installed a set or Revolutions with Yoko A008s (the tires came with the rims)
4) Installed the rear fenders
5) Installed the windshield
6) Installed the headlamp bulbs - I have to have the car inspected to get it registered
7) Installed a set of windshield wipers
8) Installed 7/16" dia front wheel studs to match the rears
9) Removed a couple of added on aluminum panels and found the original Lotus data plate with s/n
10) Tonight I loaded the car back onto the trailer to go for a DMV inspection tomorrow (if I can get away from work by 3:30):
11) Hooked up a battery and found that the starter motor would spin the engine over
12) Did a compression check:
Note: I poured a bunch of Marvel Mystery Oil in each cylinder last October after I towed it back from the original owner's place. Tonight I spun it over for a while with the plugs removed before I checked the compression and let the excess oil blow out the plug holes. All 4 cylinders showed 240 - 245 psi. Even if my gauge is completely whacked at least the compression is even across the board. Maybe I'll make enough progress to try to light it off this weekend.
