Hi, is there anyone on here that can steer me in to the secrets of being able to remap the stock MBE ECU (3AL066A - not sure if this is the model)? My car is a 2009 Duratec kit.
1) the only connector on the ECU is the main harness one, to plug in to a laptop/Easimap I am guessing that a couple of the pins on there are the CAN bus that need connecting an adapter to?
2) Once connected, I believe the factory ECU's are PIN protected, is that so? Does anyone have the PIN?
3) If all else fails and I buy a MBE9A4 ECU does anyone have an appropriate map as a starting point to work from?
Initially I am planning on taking the stock "175" setup and keeping the intake, going to stage 2 cams and springs, bigger injectors and re-tuning. Later on I may add throttle bodies to the equation.
Thanks in advance.
Thanks in advance.
