The little green turn signal light (center of three lights on the tach face) on my car has taken to glowing and/or flickering when the turn signals are not in use. The glow waxes and wanes, and is never as bright as when the signals are in operation. It happens whether the main/parking lights are on or off, but is more likely when they are on. Manipulating the headlight switch does seem to affect the glow. All turn signals and lights are functioning normally. I have just replaced the Banner battery with an Odyssey PC680MJ. The Banner had not shown obvious signs of failing, but it was drawing down to around 8 volts on starting, causing problems with my gauges.
Ben at Caterham USA says he has not seen this previously. Any ideas as to causes/cures?
