Yesterday I drove up to Newcomb's Ranch on the 2.
Car ran fine until I stopped for gas. It took several tries to re start the engine, (I have a hot start issue but that's another thing). The final time I turned the key I had not waited for the engine to completely stop turning from the previous crank but it started. I don't know if that's relevant but from then on the engine ran rough with the occasional "FPSST!" very short high pitched hiss or suck that could almost be mistaken for a very small rock hitting the aluminium floor. A sort of cross between a tap and a hiss. I think coming from the intake side of the car on the right.
I drove the car today and it's the same, maybe worse. Could it be running on three cylinders? Could I have blown a gasket? Or screwed up an injector?
Would love some suggestions of things to try so I can work out what it is.
As you can probably tell, I'm a fairly inexperienced mechanic!
All input gratefully received,
best,
Paul
best,
Paul
