Rear brake calipers
  • Rear brake calipers
    I've finally gotten round to putting the rear brakes back together, or so I thought. But the pistons in the calipers won't budge. I've taken the calipers right off of the car (I'm getting rid of the parking brake - it's sooo heavy :-O) so there's no hydraulic or cable tension anywhere . I remember this being a bitch when I built the car but now it's simply impossible.
    I've done this on other cars before. Shouldn't the pistons compress (I've tried pushing & winding - no dice) so that the pads go in and then the caliper w/ pads goes over the disc? What am I missing?
    You have to twist them (via a caliper twist tool or some pliers). You will have to push (harder?) them in as you twist.
    Cheers.
    EDIT: Just thought of something - maybe remove the Cap on the master to allow it to vent as you move the piston back and displace the fluid.
      You should not have to remove the cover as there is a vent hole. DO watch the fluid level as if you've added fluild as they went down, it will come back up.
      You can buy an inexpensive wind back tool from a local parts store. You do have to push and twist but it should not be too hard.
        Chris,
        Have you tried both sides or just one side? If you've only tried one side and it's not moving you may have a stuck piston in the caliper.
          From what I remember on my car, there isn't much of a vent hole. It would be easy to clog.
          This should help you out:
            I had the same trouble and found the rubber boot sticking to the piston due to grime and dust. A quick shot of WD40 made it twist and move much easier.
              gwise, thanks for the link. This quote...
              "It takes quite a lot of effort to force the pistons back into the calliper body. A lot of effort."
              seals the deal.
              As I mentioned, I took the calipers right off of the car. It was clear that the force required implied that I stood a very good chance of doing something stupid and breaking something. I guess I'll have to get a proper tool for winding. Whatta pita (well, pitw - wallet - actually). The AP brakes at the front have no such issues. It's almost enough to make me spend the $500 or so for the racing rear calipers. Almost.
                have u tried a c-clamp in the sliding rear caliper. I know it has always worked on fixed calipers.
                  Talk to Doug about his wilwood calipers before you buy the bespoke English thing. Might be cheaper.
                    I've not yet done the Wilwood upgrade to the rears, only the Outlaws to the front. Magnus recently did his fronts as well - we have the non vented disks.
