Replacing a bad Bendix
  • Replacing a bad Bendix
    Hey everyone,
    Ever had to replace a Bendix gear that missing some teeth? Do you have to replace the entire starter? What is a good source for parts? My car is an early Caterham S3 (1975).
    You should be able to replace just the bendix.
    I get my stuff from Wagner Alternator in Chino.
    http://www.wagneralt.com/
    Rick Wagner made the mistake of being incredibly helpful for a relatively small sale so they are my first choice.
    Check the flywheel ring gear too. Hopefully OK as that's an engine out deal.
      Excellent. Thanks Doug.
        I might also have a complete cross flow starter that I no longer need.
          Thanks Doug. I'll let you know what I find out. Might take a few weeks as I'm out of town.
            If your starter is under the headers and doesn't work well when hot, the best thing might be one from this guy.
            http://www.gustafsonmachine.com/
              Hmm... I wonder how much they weigh... :D (kind of)
                The adaptor and case are aluminum. It weighs much less than the iron hunk it replaced.
                  Once I know if this is a Bendix gear or solenoid problem, I'll let you gents know. After all, it IS an old Caterham with an original Lotus Twin Can motor in it, (mid-1970). I suspect that there are a few teeth missing off the Bendix. We shall see.
                  --Dave
                    [Issac Hayes voice on] Oooh Yeah [Issac Hayes voice off]
                      8.5 lbs (sort of):)
