New rotors (Moss Motors - paid them a visit Saturday - nice fellas!) in the garage now, w/ the old ones off. I assume it's an impact wrench (ain't got one) to get the hubs off the old and on the new. Correct? Any known torque value?
Hey Doug / Magnus
I used an impact but here is another way.
http://alcester-racing-sevens.com/hi_spec_4-pots.htm
Or go to Harbor Freight, Home Depot, or Sears and buy an inexpensive impact driver.
1/2" drive.
Have you installed your uprated spindles yet?
DougLast edited by Doug Liedblad; January 17, 2010, 10:35 PM.
Thnaks for the 'top tip' (English English!) Doug. Fronts off now - I'll be having a look at the hubs later today. I'm hoping a local brake shop can press the old bearings out. Blat Chatters say putting the new in can be done w/out a press. MM, if you're still around, any tips?Chris
I've always clamped the disks in a vise and used a regular socket to get the bolts holding the hub out.
The upgraded hubs use conical bearings that slide right off the spindle. I believe the stock hubs are identical in this matter. I usually tighten the main hub nut, which holds the conical bearings against the tapered hub hole, until the washer behind the nut offers a bit of resistance as I move it around with a screwdriver.
I reused them on M. Murphy's car the one time we worked on his disk brakes.
I have green locktite for holding pressed cylinderical parts together. According to the the specs RED is stronger.
If the hubs get >150آ؛ C it doesn't matter as the locktite has lost it's strength.
Check here: http://www.triumphspitfire.com/Torque.html
Originally posted by Doug Liedblad View PostIf the hubs get >150آ؛ C it doesn't matter as the locktite has lost it's strength.
I use #262 (red) on fasteners subjected to heavy shock/vibration loads. This would be a perfect application for 262. I also don't think you're going to see higher than 300deg F on a hub.
Originally posted by Doug Liedblad View PostI have green locktite for holding pressed cylinderical parts together. According to the the specs RED is stronger.
Whatever you use, make sure you use brake cleaner and get all of the oil and drirt off the thread.Last edited by GWise; January 25, 2010, 06:11 PM.
You can use this instructional video as a motivator to get things right.
http://www.youtube.com/watch?v=jv4m41viy4I
