Lost 15 lbs, gained 5 back
    The real test will be when the engine and starter are hot.
  • sdcat
    started a topic Lost 15 lbs, gained 5 back
    I put in a new smaller battery, 6 lbs compared to the 21 lb one I had! Doug, you'll be happy to know that I now have mounted a fire extinguisher. Cost me 5 lbs, but well worth the weight!
    Anyone else use a 6 lb Braille battery? It started the car fine, so I'm hoping it is adequate.
    Justin
