New hub and tie rod
  • New hub and tie rod
    The good news is that I've replaced all of my suspension bushings, bearings, rod ends, and grease boots. At the same time, I replaced the standard front hubs with the upgraded hub kit. The ride is much tighter! Of course, this hasn't been without a few glitches! Anyone else have problems with clearance between the tie rod covers and the front brake rotors after putting on upgraded front hubs? I've got about 1/8 inch between the tie rod end and the brake rotor, which is fine, except that the grease boot rubs against the rotor.
    I've had that upgrade sitting by the tools for about a year. What a slug. I'm from New Mexico you see, the land of manana.
    Did you have to have someone press the old bearings from the uprights?
      Yes, I have to admit that I had a shop here help me with it. I've replaced bushings and hubs in other cars before, and didn't have the patience to do it all myself!
        My car was built with stock brakes, then upgraded to the AP vented set up. My clearances seem to be about the same as yours, maybe 3/16". My grease boots appear to be barely touching the rotor, but in 1 1/2 years of use (6100 miles) including about a dozen autocrosses, I've had no leaks. I just went out and checked the boots, and they are undamaged, as far as I can tell. It appears the front end geometry is such that it would be hard to move any of this stuff, even a little bit, without screwing up the alignment in some way. Perhaps a spacer or shim to move the rotor out, but who knows what that would do to wheel location and front wing clearance? I am, however, pretty much an idiot when it comes to these things, so I would take anything I postulate with a bucket of salt!
        Brad
          Why not just go to rose joints?
            Good idea. I have rose joints on the upper A arm. I'll look to see if I can find some for the steering arms.
