I recently had a garage/shed made, mainly for the Seven and tools. There is a 12" drop from the garage floor to the ground. I eventually plan to have a concrete ramp made with a driveway that connects to my current driveway, but for now I need to make something that will get me by.
At first I was going to make something out of plywood, then I started thinking of practicing my welding on some angle iron and metal mesh like the ramps you see on the back of utility trailers. I'm not sure if that would be strong enough (I'm not an engineer by any means!). Any suggestions on these ideas, or any other way of making a sturdy but relatively cheap ramp?
Here is the unit:
Here is the unit:
