To make it easier to add/remove/ check the transmission oil level.
I got this idea from Blatchat.
The idea is to install a removable plug on the T9 top cover so you can check the oil level, change, or empty it before removing the transmission without the bother of the very limited access side plug.
When first installed I made a dipstick and calibrated by filling to the overflow plug.
I used a short 1/2-20 bolt and nut, with the nut brazed on inside of the cover, an O Ring for a seal. Works fine.
Sean added to this by using an O2 Sensor bung and plug. Better idea as it is a bit larger. You can find the plugs with a crush washer too. These are typically the same thread as a spark plug.
I put mine in the left front corner of the cover, no gears or shift forks nearby.
The cheapest bungs I've found are here:
http://www.urdusa.com/product_info.p...s_id=540000098
You can find bungs from many sources but I'd use one with the step and just braze it in. Welding may be OK but it might warp the sheet metal. With the step it cannot fall into the gearcase if the braze fails. Bad noises if this happens so be sure it is secure.
I use a venturi vacuum generator and catch tank (air compressor required) to evacuate the transmission, takes about one minute.
An alternative is this: (shop around for better prices)
http://www.motiveproducts.com/05specials2.html
