Six months now since I dropped the car off at the shop, but it's finally running. It's been a learning process for both myself and the shop. Here's a few things I learned / issues with rebuilding the ZX1:
- The machine shop had to buy new jigs just to be able to do the valve work, because of the ZX1's unique configuration. It was also difficult for them to find engine plugs. We think this must have been a European sourced engine. Parts are not as readily available for the ZX1's as later Zetecs.
- Cam choices for ZX1's are limited in the U.S. We ended up using the Kent FZ 2002's that were on it, which should be OK.
- The billet oil pump from Quicksilver only works for ZX2's onward.
- Jenveys won't work with the stock computer because the stock computer uses MAF instead of throttle position sensing.
- Once we figured out that the Emerald wasn't working because the crank sensor wasn't working, we tried many different recommended crank sensors, and the one that worked was off a ZX2.
- Once we got the car started, we found two cylinders with broken rings, probably from numerous attempts at starting while sorting out the computer/sensing issues, and flooding the cylinders with gas. The engine had to be rebuilt again on their dime.
- Last week the car finally was running smooth, but the throttle cable broke! Will get a new one Monday, and do an initial dyno tune, and then hopefully be on the road to break in the engine for a while before completing the tune.
The down side is the time it took to rebuild this thing, and the expense. It's been kind of a recurrent "just one more little thing to sort out and it should be ready," and I've had to practice a lot of patience. The shop has eaten a lot of the labor cost of rebuilding this, since they admit to it being a learning experience for them also! The up side is that is has stronger internals, balanced, better sump baffling, higher compression, porting/polishing, bigger valves, and is hopefully going to withstand a little abuse on the track. The wiring and finish of the engine actually looks quite impressive. Despite the problems the shop has had in figuring this out, they have quite a bit of experience building race engines, so I hope this engine runs well for a few years.
Can't wait to get it home to rebuild the suspension and brakes, and put the garage full of toys I've been accumulating in the meantime on it.
