Seven CustomTrailer
  • Seven CustomTrailer
    I was wondering if anyone out there had a lead on a Seven specific trailer, or someone who can make one for a reasonable price.
    I want something of minimum size to pull the car. I think someone in the Bay Area bought the trailer off Will (Southern Cal Sevens) recently, if they are on this list, I would appreciate an opportunity to take some dimensions and photos if possible.
    Any advice or guidance would be appreciated....
    Magnus and I had some made at Mighty Mover of Corona. Came in around 2 grand but we both (I think) optioned them up to a little more than that. It weighs under a thousand lbs. and pulls like a dream. It took the vendor about 5 or 6 weeks to work them into their production cycle. Google will reveal their website.
      I have looked at getting one made locally (Bay Area) and found a company that will do it for $1600 for a basic drop axle unit with no shiny bits. I really wanted to look at some dimensions and specs to make sure I was doing the right thing.
      Ian
        Just make sure to get one with surge or electrical brakes, which would be sensational for $1600. AFAIK this is required by CA vehicle code if over 1500 lbs loaded weight no matter how big the tow car. Normally not a big deal but it may become an insurance headache in an accident.
          From the CA DMV Website.
          26302.
          (b) Every trailer or semitrailer manufactured and first registered after January 1, 1966, and having a gross weight of 3,000 pounds or more shall be equipped with brakes on at least two wheels
          A lightweight trailer and Caterham should be well under.
            Ah, thanks. I found where I had seen that....the 1500 pound limit applies only to camping trailers ("trailer coaches"), not to other trailers.
            Well, might be a good idea to have brakes, anyway. At least with a rather lighweight tow car like mine.
              Some of the formula ford racers use a trailer that is close in size to what you'd find for a Caterham.
              Here is a website that has listings www.apexspeed.com
                Thanks! I will keep an eye on that site.
                  I bought Will's trailer. If you want to come by and inspect it to check dimensions, you can do that. The car is sitting on it. Send me a PM if interested.
