New from Hartley
  • New from Hartley
    Anybody think this would be good in a seven?
    http://www.h1v8.com/H2.html
    What tranny would you use?
    All of the hayabusa sevens I have seen have the engine leaned over to the left...not a problem on a RHD car, but for us here in the USA it puts the weight all on one side as well as interfering with the pedal box. I wonder if this kit could help move the engine to a more traditional location?
    Would be very good in a Seven, IMHO. Regarding the gearbox, the "Pricing" page had the following listed as one of the options:
    "Special small diameter bellhousing to mate the H2 to a Ford Sierra type 9 gearbox. The small diameter allows the engine and gearbox to be lowered significantly as the lowest part is about 116mm from the crank centerline... $625"
    Regarding the offset to the left in a typical Hayabusa installation, it appears that would not apply here, because the Suzuki gearbox is not used here. There is a pdf drawing on the "H2 Specs" page that depicts the flywheel at the end of the crankshaft.
    Wild.
      Sean,
      It's cool that it can bolt up to a std transmission, however I thought one of the nice things about using a bike engine is that they come with a sequential transmission.
      I also wonder about the weight difference with this hartley kit + t9 transmission vs a std engine + t9.
