New shock in.
  • New shock in.
    Attached are corner weights.
    It seems like losing the Zetec and supercharger saved me 70 lbs, which is quite a bit.
    The car is now almost exactly at its spec weight with 1287 lbs (without me). That is with the anchor 15" wheels. 13" probably saves me another 10-20 lbs or so.
    Attached is the final corner weight I got with me in the car. Comments about my weight are best kept to yourself, thank you very much.
    /Magnus F
    If it makes you feel better.... you got me beat by 150lbs (overall, not bodyweight :wink:)
      Cross weights look great. How does the front - rear percentage compare w/ the old rig? I wondering because you had understeer issues before didn't you? Have you had a chance to use it at the limit after the flat flooring?
        Here is the old corner weight setup with the Zetec.
        The Duratec gave me a bit better left/right distribution. With the Zetec I had a bit less weight up front, but I am fairly positive due to the fact that I had more gas in the tank when I did that engine since the old engine package was heavier. This also explains at least a part of the 70 lbs, which was a bit too good. I was expecting 40-50 lbs.
          Hood is on.
          I also built a simple catch tank from a simple bottle with a breather hose and some silicone. We'll see if it works.
            I really like the color of the new hoo... er, bonnet.:D
              Took the car to work today with the new radiator, hood and shock.
              According to the laptop, it runs a bit cold with 178F exit temperature from the engine on the freeway with an ambient temperature of around 68F. The temp hits 220 when idling. I do think, however, that the temperature sensor is a bit off since we I see lower values with an IR thermometer.
              The obvious reason for the cool running is that I don't have a thermostat since the old radiator was so small and clogged up it needed all the flow it could get.
              I'll re-install the thermostat tonight. With a bit of luck I will be at Buttonwillow this weekend to support the shakedown of a time attack car with a Magden setup in it. I will bring the Caterham to see if I can get some track time.
                Do you have an oil temperature sensor?
                According to Redline Oil their oil works best over 160 and over 200 is better.
