Probably the most expensive parking lot ever built, and exclusively for raspy sounding high polar moment of inertia air cooled tractors. I wonder if they left enough space for all those famous racing Volkswagens too?:D
I’m not sure where you get the idea that the Porsche tractor has a high polar moment of inertia. As you can see, all the major components are located within the wheelbase which should help create a low polar moment of inertia. Perhaps you meant to write that it has a high center of gravity? I’d certainly have to agree with you there. Regarding sonics, having heard them run, I can assure you that the exhaust note is more clackity than raspy. :D
BTW don’t forget that the tractor line has always been on the cutting edge of aerodynamics.
