I spent three happy hours with Bisi Moto yesterday with Mr Bisi running the car and dyno while I did the mapping. Scott E joined us and hung out with us in the shop.
We ended up taking out a huge amount of fuel over the entire map and added 4-6 degrees of ignition over the entire rpm range at max load (max TPS).
The verdict is attached: 217HP/181lbft at the wheels. With a 17% drive train loss in gearbox and diff, we are looking at ~252HP at the crank.
The supertrapp took out approx 12 hp at the wheels. Bad, but not catastrophic. I have a map that runs 2% leaner for when I run with the supertrapp installed. One day I will find a better muffler solution.
The attached chart shows the final power run with and without the supertrapp.
The only downer to the day was we found a huge gash in the rear tire after something I've run over and that my altenator died on the way home and I had to tow the car for the last bit.
I am not sure I will manage to get a new set of rear tires (Kumho V710) and a new alternator in time for Friday, so I may have to cancel Willow Springs.
